[SOLVED] full bridge converter with mosfet and IR2110 gate driver
Powerelec_sci
Newbie level 5
Indore(M.P.) india
I have a problem in IR2110 gate driver. I have given PWM at Hin(in phase) and Lin(out phase). The IC is working on the high side(Pin no1) but it is not working on the low side of the IC(Pin no 7). I have tried all the configurations but it is still not working. Please suggest me any remedy to my problem..
Re: full bridge converter eith mosfet and IR2110 gate driver
Dear pinki verma
Hi
Can you attach the schematic that you follow it ? By the way : did you try it in practice or perhaps you used a simulator ?
Best Wishes
Goldsmith
Thank u for ur reply, i have attached the image ofmy schematic with this post. i tried this circuit on bread board but with no luck. do suggest me a way out.
Is COM (pin 2) attached to the negative rail of the H bridge? Other than that your schematic looks fine.
Yes , i'm agree with mtwieg , com , should be connected to the source of low side mosfet .
