full adder .. please help with checking the program
OKcomputer6
Newbie level 1
full adder .. help
i have just learned to write on vhdl and I have completed my first full adder code using components for the xor, and, or gates but im not sure if its right, could someone please tell me if this is right? I do not have vhdl ive written this on notepad..
-- For XOR gates:
library IEEE;
use IEEE.std_logic_1164.all;
Entity XOR_1 is
Port (x,y : in std_logic ;
z: out std_logic)
Architecture behavioural of XOR_1 is
Begin
Process (x, y)
Begin
If (x /= y) then
z <= ‘1’;
else
z <= ‘0’;
end if;
end process;
end XOR_1;
-- For OR gates:
library IEEE;
Entity OR_1 is
Port (a1,b1 : in std_logic;
c1: out std_logic);
End OR_1
Architecture behavioural of OR_1 is
Begin
Process (a1, b1)
Begin
if ((a1 = ’0’) and (b1 = ‘0’)) then
c1 <= ‘0’ ;
else
c1 <= ‘1’ ;
end if;
end process;
end OR_1;
--For AND gates:
library IEEE;
Entity AND_1 is
Port (i1,i2 : in std_logic;
out1 : out std_logic);
end AND_1;
Architecture behavioural of AND_1 is
begin
Process (i1, i2)
Begin
If ( (i1=’1’) and (i2=’1’) ) then
Out_1 <= ‘1’;
Else
Out_1 <= ‘0’;
End if;
End process;
End AND_1;
-- Full_adder:
library IEEE;
entity full_adder is:
port (a,b,c : in std_logic;
c_out :eek:ut std_logic;
S1, temp1, temp2 ,temp3 ,ctemp : inout std_logic);
-- I used inout mode for ports used as an output in some statements and then as input in other statements.
end full_adder;
architecture structural of full_adder is:
component XOR_1 is
port ( x,y : in std_logic ;
z : out std_logic) ;
end component XOR_1;
component OR_1 is
port ( a,b : in std_logic ;
c : out std_logic);
end component OR_1;
component AND_1 is
port ( i1, i2 : in std_logic;
end component AND_1;
begin
xor_ab : XOR_1 port map(x =>a, y =>b, z=S1) ;
xor_c : XOR_1 port map(x =>S1, y =>c, z=S) ;
and_ab : AND_1 port map (i1 => a, i2 =>b, out1 =>temp1) ;
and_ac : AND_1 port map (i1 => a, i2 =>c, out1 =>temp2) ;
and_bc : AND_1 port map (i1 => b, i2 =>c, out1 =>temp3) ;
or_ab : OR_1 port map (a1 => temp1, b1 => temp2, c1 => ctemp) ;
or_abc : OR_1 port map (a1 => temp3, b1 => ctemp, c1 => c_out) ;
end structural;
thank you!
