1icarus1
Junior Member level 3
ft323r
MODERATOR ACTION: topic moved from microcontroller section to here Fragrance
Hallo,
I would like to use the FT232R it in 2 different ways:
1st: My circuit will supply the FT232R and an external device with 5V / 75mA and will comunicate with this via the USB connector.
2nd: Using the same connector I would like to remove the external device and connect a PC.
The problem is that once my circuit supplies the connector and the FT232R with 5V how could I connect a PC? The PC gives it's own 5V supply, so supplying the connector and the FT232R with my 5V regulator and simultaneusly connect a PC is a very critical connection.
Does anybody can help me on this issue?
Thanks.
Hallo,
Thanks.
