FSK transmitter and reciever
mohsen81
fsk transmitter and reciever
Hi
I want to build a FSK transmitter and reciever.
Could you help me how to build it .
I need the schematics
thank u but i want to build a discrete FSK transmitter and reciever, not by using one chip which does all of the modulation.
I want to build each part of modulator and demodualtore seperately !
what frequency?
Hi
Frequencies in ISM band or 1-10 MHz or 433 MHz
use the PLL as the FSK transmitter and the receiver
ISM band : 900MHz. **broken link removed**
The site shows LNA, VCO, Mixer, VGA...receiver.
You'll have to add a PLL (which you'll buy) to control the VCO
You'll have to create the FSK modulation on your own...
the project will be difficult because i think you'll need to build each block individually and test each. then add all building blocks together.
UCLA also has built a discrete transmitter / receiver that i've seen on the internet.
i'm not sure what kind of commitment you want to put in because if you build a system from a schematic, it still may not work...let me know.
Hi
I want to send digital data over a wireless network as FSK or DTMF.
RF link is present (VHF transceiver)
I have to only encode and decode data using FSK at both ends
Which is the simple solution to do the encoding and decoding.
Any readymade low cost modules or chips or any arrangement ?
please
picstudent
NE565 may be used for FSK.
MT8888 MT8870 for DTMF
