FSK modulation - simulink
ashwini1
Member level 1
Bangalore
fsk modulation
I am new to digital communication area. I want to FSK modulate my .wav file and also demodulate it in simulink.
After going through matlab documentation and demo, i found that FSK modulator (in simulink) accepts only integers as input. I am unable to convert my .wav file into integer and feed it to FSK modulator.
Can anyone guide me, how to start with this and what all steps to be followed to modulate and demodulate the .wav file.
Thanks !
Ashwini
fsk modulator
did you checked the mathwork web site?
also, send a private message to communication_engineer in this forum.
Added after 3 minutes:
just check this link which will guide you to the contact of communication_engineer which is a member in this site
what is fsk modulation
thanks for ur reply..
i checked in mathworks website .. but could not find any example where .wav file is used as input to fsk modulation.
fsk modulation in simulink
ok contact communication_engineer as i tolled you by this link
Added after 1 minutes:
told him to see this post
modulation fsk
Got the solution myself ... if anyone facing similar problem i can post my model.
Do let me know ..
Thanks !
Ashwini
please i need the solution of the problem! can you post it?
Re: modulation fsk
Can you post your model pls?:roll::roll:
