$fsdbDumpfile problem
tarkyss
Full Member level 6
China
fsdbdumpfile
how to let Modelsim recognize $fsdbDumpfile function?
$fsdbdumpfile
Procedure for dump fsdb use ModelSim(winnt , verilog)
1.install Modelsim
2.install Debussy
3.
//add fsdb PLI in your testbench
initial begin
$fsdbDumpfile("pattern.fsdb";
$fsdbDumpvar(0,pattern);
end
4. copy debussy/share/pli/modelsim/novas.dll
copy debussy/share/pli/modelsim/novas_verilog.v
to your module directory
5. change modlsim.ini writeable(defaule is readonly)
mark Veriuser=....
then add veriuser=novas.dll
6.use modelsim to compile your design, don't forget include novas_verilog.v
7.simulate -> Run All -> finish
you will see pattern.fsdb in this folder
becsuae many people ask about this question,
so I re-write a more clear procedure.
enjoy it!
modelsim fsdbdumpfile
but i cannot find novas.dll
my debussy version is 5.4v10
modelsim version is 6.1a
Check with the document "Linking Novas File with Simulators to Enable FSDB Waveform Dumping" which is located in $DEB_DIR/doc
