PIC18F4550
Full Speed USB 2.0 (12Mbit/s) interface
1K byte Dual Port RAM + 1K byte GP RAM
Full Speed Transceiver
16 Endpoints (IN/OUT)
Streaming Port
Internal Pull Up resistors (D+/D-)
48 MHz performance (12 MIPS)
Pin-to-pin compatible with PIC16C7X5
The Microchip® PIC18F4550 microcontroller is loaded with features, including a large 32kbytes of program memory, optimized for C programs and including a hardware multipy. This microcontroller also features a total of 13 input A/D channels, making the system ideal for use in real-world monitoring applications. The PIC18F4550 Development Board comes complete with the Microchip PIC18F4550 microcontroller pre-installed, together with the necessary crystal and power supply components, for a ready-to-run solution. Simply connect the power and download your program, using the easy to use programming interface and software, and your ready to start exploring the new PIC18 USB Microcontroller.
http://ww1.microchip.com/downloads/en/DeviceDoc/51679b.pdf
Microchip USB Device
Firmware Framework
User’s Guide
