srevish
Member level 2
Hi all,
I am using zener diode in my circuit, basically I am using this circuit as a water level sensor. Please find the attached file for the circuit diagram.
This 10V/3W zener is supplied 24Vdc, then the 10 V is drawn by a sensor of 120 ohms & by a resistor of 47 ohms.
Thus the current flowing zener diode is 0.083 A
R total = 120 + 47 = 167 ohms
I = 14/167 = 0.083A
Power on zener = 0.083 * 10 = 0.83 W
As per the derating, we have used 3 W zener diode.
But we are having frequent failure in the zener diode.
Can any one tell me what would be the root cause for this failure & is there is any way to stop it.
The sensor ( 120 ohms ) is off heating type, this will be in heated position always.
I = 14/167 = 0.083A
