Afaik FSK is for data transmitting, but you talk about power transmitting.
What do you realy want to do?
Klaus
Are you talking about the smart cards that get the power from the RF signal?
You are talking about a proprietary system designed by yourself or a system according to an existing industry standard? Which communication direction do you intend, power transmitter to receiver, reverse direction or both?if already power transmission design exists could we use FSK modulated signals over power coil ? if yes How to design such FSK modulator
Simplest way is to use a digital frequency divider, and switch between two different division ratios.Hi ,
I would like to design and test a FSK modulation method so that it can be used for wireless power transfer receiver Coil.
Thanks
