hiz. i have not much code skill. im using PIC16F877A
after reading many codes, i make a code of CAPTURE module to calculate the frequency. my code is giving me some value regarding the frequency (having direct result from Capture Low and High register CCPR1H and CCPR1L).
now i stuck to decode it into correct frequency measurement
im using 4MHz crastal with Tosc and 4prescaler value and coding in C
yah.... but i want to do it by capture module. i also planning to add RPM with it. thats why i need Capture module code with interrupt. is anyone having the code of capture module. kindly post it.
the capture module should calculate anything, time period, frequency or anything.
the only problem i m facing with flag (interrupt) control.
