Frequency/Magnitude response of lowpass FIR filter
Naveed Ahmed
Member level 4
Singapore
I have written a test program in matlab for lowpass fir, when i m plotting its magnitude response after fft, it seems to be a high pass filter. Why its doing so??
My code is as follow:
N=50; %Filter order
Length=N+1; %length
n0=N/2; %delay parameter
n=0:1:N;
fc_l=1/8; %Cut off frequency for the low pass filter
Wc_l=2*pi*fc_l;
%===================LOWPASS FIR FILTER=====
h_lp=sin(Wc_l*(n-n0)) ./(pi*(n-n0)); %Impulse response of Low Pass FIR filter For n-n0!=0
h_lp(n0+1)=(Wc_l/pi) %Imp response of Low Pass FIR filter For n=n0 or n-n=0
F=fft(h_lp,51);
X=real(F);
Y=imag(F);
[th,Mag]=cart2pol(X,Y);
plot(0:50,Mag)
Thnks,
ur comments plz
naveed
if you do this
f=(0:50)/50
plot(f,Mag)
your plot will be normalized and you see the relevant part which is 0 to 0.5
the part higher than 0.5 is the negative spectrum (0.5 is the nyquist frequency)
your filter is correct.
best regards
---------- Post added at 09:21 ---------- Previous post was at 08:53 ----------
Hi Naveed,
here is a slight modification that will show the spectrum of your filter
N=50; %Filter order
Length=N+1; %length
n=0:1:N;
Wc_l=2*pi*fc_l;
F=fft(h_lp,1024); %% 1024 higher frequency resolution
F=fftshift(F); % moving the zero-frequency component to the center
% X=real(F);
% Y=imag(F);
% [th,Mag]=cart2pol(X,Y);
% plot(0:1023,Mag)
f=(-512:511)/1024 % Normalised Frequency vector (-0.5 to +0.5)
plot(f,abs(F))
Thanks chahid,
Its showing now, there is another method aswell, we can use the builtin freqz command... freqz(h_lp)
But it shows us in normalized frequency mode, we need to convert that. Whats the conversion relation between normalized freq to hz??
Thx
Hi Ahmed,
In normalized spectrum means sampling frequency = 1 you have just to multiply by
the sampling frequency to get it in hz. or use directly
freqz(h_lp,1,1024,Fs) Fs is sampling frequency if you put Fs=1000 hz you get
the cut frequency = fc_l * Fs
