buyan
Junior Member level 3
pll bandwidth maintain divider
I have designed a PLL for 4000MHz output using a 20MHz REF from OCXO with synthesizer ADF4106. Loop filter is passive.
I use a divider to get three 20MHz REFs. One connects to Oscillator Scope, the second one is for PLL REF and the third one connects to a RS signal generator. I use a passive mixer to down converter the 4000MHz to 20MHz with LO from the RS signal generator. Then I connect the 20MHz output from the mixer to the Oscillator Scope too to compare with the REF 20MHz.
However, I found that the 20MHz output from the mixer is drifting during 12 hours continuously running watching period.
Please kindly advise what are the possible reasons? Thanks.
