Frequency Divider in VHDL
vlsi_freak
Full Member level 2
vhdl frequency divider
Hi.
I am trying to divide a clock by 2, and have the VHDL code is given below.
Now the clock here is divided by 4,,OOOppsss.
How can i write a VHDL code to divide the frequency by 2.
Thanks.
entity freq_div is
port (
clk, rst, d : inout std_logic;
q, qbar : inout std_logic
end freq_div;
architecture freq_div_a of freq_div is
begin
process(clk, rst)
begin
if (clk'event and clk='1') then
if rst ='1' then
q <= '0';
qbar <= '1';
d <= '0';
else
q <= d;
qbar <= not d;
d <= qbar;
end if;
end if;
end process;
end freq_div_a;
Please share your ideas.
vhdl code for frequency divider
To divide-by 2 just use a D-FF with the Q-bar output tied back to the D input..
This is the basic divide by 2 ckt.. it works..
Reactions: Aya2002
    vlsi_freak
    Aya2002
frequency divider vhdl
by right, ur coding should divide the clk by 2. I cant see any wrong form ur coding. Are u sure it divide the clk by 4?
vhdl clock divider
In your code each statement will implement as a FF.
qbar <= not d;
d <= qbar;
These statemets will be implemented as two FFs in series as show in the figure
Regards,
Kanags
Added after 7 minutes:
Please replace the buffer with NOT gate.
Reactions: Aya2002
    vlsi_freak
    Aya2002
clock divider vhdl
ya kanagavel_docs is right,just realize whats wrong when kanagavel_docs point out the error.
Thats why the clk div by 4 not 2.
vhdl code for clock divider
Is this fine?
entity divbytwo_dff is
port(
din : inout std_logic;
q : inout std_logic;
clk,reset : in std_logic
end divbytwo_dff;
architecture a_divbytwo_dff of divbytwo_dff is
begin
process(reset,clk)
begin
din <= not q;
if(reset = '0')then
q <= '0';
elsif (clk'event and clk = '1')then
q <= din;
end if;
end process;
end architecture;
Re: vhdl code for clock divider
Delete red parts and you will divide by 2.
Is this fine?
port(
end divbytwo_dff;
begin
process(reset,clk)
begin
din <= not q; -- delete this line
if(reset = '0')then
q <= '0';
q <= din;
end if;
end process;
end architecture;
Reactions: Aya2002
    Aya2002
