Bandwidth of BPF is determined by this formula.
BW= fh-fl;
where fh is higher cutoff frequency and fl is lower cutoff frequency.
You have mentioned only higher cutoff frequency.
So if you have lower cutoff frequency you can calculate using the formula given.
