ilamseeker
Member level 1
Dear All,
I am using two MCF5213 Evaluation kits: one for generating the PWM waveform and the other for checking the period of the generated PWM waveform.
I am using he DMA timers to check the time period of the pulse. I have configured it but it is giving incorrect value in the DTCR(counter) register.
I am using DTIN1 pin for giving the pulse input which has the period of 0.8ms but the value in the counter turns out to be 264244026.
which gives 264244026/(80 * 10^6) = 3.303050325 which is incorrect. Please check the code and let me know if i am doing something wrong here
thanks
I am using the following code:
int main(void)
// Enable the directions pins TC[1]
MCF_GPIO_PTCPAR = 0
| MCF_GPIO_PTCPAR_DTIN0_DTIN0
| MCF_GPIO_PTCPAR_DTIN1_DTIN1
| MCF_GPIO_PTCPAR_DTIN2_DTIN2
| MCF_GPIO_PTCPAR_DTIN3_DTIN3;
MCF_DTIM_DTMR(1) =
MCF_DTIM_DTMR_PS(0x00)
| MCF_DTIM_DTMR_CE_RISE
| MCF_DTIM_DTMR_CLK_DIV1
| MCF_DTIM_DTMR_RST;
//Setup the interrupt registers for DTIN[1] & DTIN[3]
MCF_INTC_IMRL &= ~MCF_INTC_IMRL_MASKALL
& ~MCF_INTC_IMRL_INT_MASK20
& ~MCF_INTC_IMRL_INT_MASK22;
MCF_INTC_ICR(20) = MCF_INTC_ICR_IP(4) | MCF_INTC_ICR_IL(4);
mcf5xxx_set_handler(64 + 20, direction12_handler);
mcf5xxx_irq_enable();
while (1)
printf("the value of the counter is %d \n", counter);
__declspec(interrupt) void direction12_handler(void) {
counter = (long int) MCF_DTIM_DTCR(1); //Read the encoder counter
MCF_DTIM_DTCN(1) = 0; //Reset the encorder counter
MCF_DTIM_DTER(1) |= MCF_DTIM_DTER_CAP;
thanks
int main(void)
MCF_GPIO_PTCPAR = 0
MCF_DTIM_DTMR(1) =
| MCF_DTIM_DTMR_RST;
while (1)
