[SOLVED] [FPGA]Wierd instantiate in Xilinx FPGA
TuAtAu
Jupiital
I descripe my BRAM in a .vhd and synthesized and it is workable.
But when I use them in lower hierarchy, It cannot instantiate as the BRAM!!
WHY?!? what's going wrong?
Bottom 2 pictures will explain everything.
My BRAM code:
architecture Behavioral of BRAM_2s14_49bit is
	type BYTE_RAM_TYPE is array (0 to 16383) of std_logic_vector(48 downto 0) ;
	signal BRAM 				: BYTE_RAM_TYPE:= (others => (others=> '0'));
begin
	process (CLK)
	begin
		if (CLK'event and CLK = '1') then
			if (ENABLE = '1') then
				if (WRENABLE = '1') then
					BRAM(conv_integer(ADDRESS(13 downto 0))) <= DATA_IN;
				end if;
				DATA_OUT <= BRAM(conv_integer(ADDRESS(13 downto 0))); --if correct, cache out
			end if;
		end if;
	end process;
end Behavioral;
1. BRAM SUCCESS in MEMORY UNIT
2. WHY NO BRAM?? BUT OVERFLOW my slice and gates!
TrickyDicky
Advanced Member level 5
I can only think of 2 things:
1. The connections arnt quite right in the 2nd picture
2. Its a synthesis bug.
For 1. Make sure clock, write enable and enable are all synchronous
2. Report the problem to Xilinx.
Reactions: TuAtAu
    TuAtAu
TuAtAu
Jupiital
What do u mean by synchronous and asynchronous? Any example? Thanks.
TuAtAu
Jupiital
add
attribute ram_extract : string;
attribute ram_extract BRAM is signal : "yes";
solved
