FPGA Smaller Packages
OvErFlO
Full Member level 3
I need to insert an FPGA into a little box 20mm x 20mm and I need to know the most smaller FPGA package , can anyone help me ?
thanks
Overflo
Although I expect that you can read data sheets: Up to 324-pin FBGA fits, also up to 484-pin UBGA, avaliable e. g. with Altera Cyclone III. If you want to have some other parts on the same surface, a 164-pin MBGA with 8x8 mm would be pretty small.
P.S.: Please don't tell, that you can't process BGA packages.
If you adopt FPGA with BGA package, you had better reserve test points or test components as possible.
FvM said:
Although I expect that you can read data sheets: Up to 324-pin FBGA fits, also up to 484-pin UBGA, avaliable e. g. with @ltera Cyclone III. If you want to have some other parts on the same surface, a 164-pin MBGA with 8x8 mm would be pretty small.
no problem ;-) thanks
