fpga jtag port dont't work ?
ZFDok
Junior Member level 2
configuration fpga jtag
i have do two pcb fpga board , but they dont work good ,the jatg port does not download bit file ,the error report is read ID 11111111111..., not the correct ID number, one know the reason,who can help me?thanks!
parallel cable iii jtag deviceid
Sounds like your JTAG connection is broken or your board is dead.
What type board? What type FPGA? What software are you using? Are there any other devices on the JTAG chain?
Check the web site of the software vendor to see if they have any service announcements such as "oops we broke the JTAG with certain devices, so please download a service pack".
fpga jtag no hardware
i am use the xc2s15-vq100 and xc2s50-tq144, the two board all sigle chip on the jtag ,no other device, the tdo pin always high level, i use ISE7.1 of xilinx software develop kit. i check the board ,i use series slave mode can config success and work good.
xilinx impact setpreference
Are you using the Xilinx Parallel Cable IV interface unit? If you are running Win2k or WinXP, did you allow the ISE installer to install the device driver that provides access to the parallel port?
Are you using the Xilinx iMPACT utility? What happens if you launch iMPACT and click File -> Initialize Chain?
TDO isn't working? How about TDI, TCK, and TMS going into the FPGA?
setcable svf
the host work is no problem, before i have a debug board with xc2s100-pq208, it can word ,but last it don't work ,i discover the tdo ,tms tck have signal all, but the device id is 000011111111111, why the device id read not correct? i use the parallel cable III. the mode select is right .
windrvr6.sys download
"it can word ,but last it don't work" -- sorry but that doesn't make sense.
Is your TDI working? That's important too.
If I unplug my FPGA board from my Parallel Cable IV, iMPACT reports ID = "00001111111111111111111111111111". That sounds similar to your problem.
What happens if you launch iMPACT and click File -> Initialize Chain? Do the error messages say anything interesting?
info bat jtag
the initial chain appear the communication with the cable cound not be established.
xilinx jtag status word impact id
Have you tried setting the config mode (M0, M1, M2) to boundary-scan?
windrvr6.sys ücretsiz indir
hi all
I meet this problem too!
// *** BATCH CMD : setPreference -pref UserLevel:NOVICE
// *** BATCH CMD : setPreference -pref MessageLevel:DETAILED
// *** BATCH CMD : setPreference -pref ConcurrentMode:FALSE
// *** BATCH CMD : setPreference -pref UseHighz:TRUE
// *** BATCH CMD : setPreference -pref ConfigOnFailure:STOP
// *** BATCH CMD : setPreference -pref StartupCLock:AUTO_CORRECTION
// *** BATCH CMD : setPreference -pref AutoSignature:FALSE
// *** BATCH CMD : setPreference -pref KeepSVF:FALSE
// *** BATCH CMD : setPreference -pref svfUseTime:FALSE
// *** BATCH CMD : setMode -bs
// *** BATCH CMD : setMode -bsfile
// *** BATCH CMD : setCable -port svf -file "E:\FPGASTUDY\pic_test\hehe.svf"
// *** BATCH CMD : addDevice -position 1 -file "E:\FPGASTUDY\pic_test\test_1.bit"
'1': Loading file 'E:\FPGASTUDY\pic_test\test_1.bit' ...
done.
INFO:iMPACT:1777 -
Reading D:/Xilinx/spartan2/data/xc2s200.bsd...
WARNING:iMPACT:2257 - Startup Clock has been changed to 'JtagClk' in the bitstream stored in memory,
but the original bitstream file remains unchanged.
INFO:iMPACT:501 - '1': Added Device xc2s200 successfully.
GUI --- Add one device.
Device #1 selected
// *** BATCH CMD : setAttribute -position 1 -attr configFileName -value "E:\FPGASTUDY\pic_test\test_1.bit"
done.
Device #1 selected
// *** BATCH CMD : Program -p 1
PROGRESS_START - Starting Operation.
Validating chain...
Boundary-scan chain validated successfully.
'1':programming device...
done.
INFO:iMPACT:579 - '1': Completed downloading bit file to device.
INFO:iMPACT:580 - '1':Checking done pin ....done.
'1': Programmed successfully.
PROGRESS_END - End Operation.
Elapsed time = 1 sec.
GUI --- PROM Formatter selected
// *** BATCH CMD : setMode -pff
// *** BATCH CMD : setSubmode -pffserial
// *** BATCH CMD : setAttribute -configdevice -attr name -value "PFFConfigDevice"
// *** BATCH CMD : setAttribute -configdevice -attr size -value "0"
// *** BATCH CMD : addCollection -name "Untitled"
// *** BATCH CMD : setAttribute -collection -attr dir -value "UP"
// *** BATCH CMD : addDesign -version 0 -name "0000"
// *** BATCH CMD : addDeviceChain -index 0
INFO:iMPACT - Elapsed time = 0 sec.
done.
Collection : Untitled
Design : 0
Device Chain : 0
Position PartName FileName
1 xc2s200 E:\FPGASTUDY\pic_test\test_1.bit
// *** BATCH CMD : setAttribute -configdevice -attr fillValue -value "FF"
// *** BATCH CMD : setAttribute -configdevice -attr fileFormat -value "mcs"
// *** BATCH CMD : setAttribute -configdevice -attr path -value "e:\fpgastudy\pic_test/"
// *** BATCH CMD : setAttribute -collection -attr name -value "Untitled"
// *** BATCH CMD : generate -generic
'1': Added Device xc17v01 successfully.
Generating Prom file using the following auto generated Prom(s):
xc17v01
0x28c44 (166980) bytes loaded up from 0x0
Using user-specified prom size of 205K
Writing file "e:\fpgastudy\pic_test//Untitled.mcs".
Writing file "e:\fpgastudy\pic_test//Untitled.prm".
Writing file "e:\fpgastudy\pic_test//Untitled.sig".
GUI --- Total configuration bit size = 1335840 bits.
GUI --- Total configuration byte size = 166980 bytes.
// *** BATCH CMD : setCurrentDesign -version 0
GUI --- System ACE selected
GUI --- Boundary-Scan File selected
GUI --- Switch to Configuration Mode
done.
GUI --- #1 xc2s200 E:\FPGASTUDY\pic_test\test_1.bit
Device #1 selected
GUI --- Auto connect to cable...
// *** BATCH CMD : setCable -port auto
AutoDetecting cable. Please wait.
CB_PROGRESS_START - Starting Operation.
Connecting to cable (USB Port).
Cable connection failed.
Connecting to cable (Parallel Port - LPT1).
Checking cable driver.
Driver windrvr6.sys version = 6.2.3.0. LPT base address = 0378h.
ECP base address = FFFFFFFFh.
Connecting to cable (Parallel Port - LPT2).
Driver windrvr6.sys version = 6.2.3.0.Cable connection failed.
Connecting to cable (Parallel Port - LPT3).
Connecting to cable (Parallel Port - LPT4).
Connecting to cable (Usb Port - USB21).
Driver xusbdfwu.sys version: 1018 (1018).
Driver windrvr6.sys version = 6.2.3.0. Max current requested during enumeration is 280 mA.
Cable Type = 3, Revision = 0.
Setting cable speed to 6 MHz.
Cable connection established.
Firmware version = 1018.
CPLD file version = 0006h.
CPLD version = 0006h.
CB_PROGRESS_END - End Operation.
Elapsed time = 2 sec.
ERROR:iMPACT:583 - '1': The idcode read from the device does not match the idcode in the bsdl File.
INFO:iMPACT:1578 - '1': Device IDCODE : 00001101101101101101101101101101
INFO:iMPACT:1579 - '1': Expected IDCODE: 00000000011000011100000010010011
Elapsed time = 3 sec.
Device #1 selected
// *** BATCH CMD : ReadIdcode -p 1
Cable is not connected.
what's wrong with it ? Can anyone help us ?
fpga jtag id code
That looks like a log of many steps. Too many. Can you insert comments saying what you tried to do at each step?
What devices are on your JTAG chain? Does the iMPACT diagram match your hardware?
I see four copies of the message "Added Device xc2s200 successfully". Why so many? If you accidentally insert duplicate copies of devices, the JTAG chain will be wrong and you will get mixed up IDCODEs.
jtag broken chain
Thank you all
My problem was solved,A PAD unconnect with PCB.
