FPGA Hardware (PCB) Design
aajizattari
Member level 3
I will be required to start working on desinging custom FPGA board (for some algorithm evaluation ) including a device from Virtex Family...
I am new in this ERA
Kindly help me in any way u can
I want to know ... related software .
What about the parallel cable/JTAG support ..is it built in or something else is needed
What about te power circuitory ...
A little feed back from u can be helpful
As to my LUCK .... there is a lot of money on hand (at least for these days)
Regards
Iouri
Advanced Member level 2
if there are a lot's of money why don't you hire someone who has expirience with that?
echo47
Advanced Member level 5
USA
One way to become familiar with FPGA hardware design is to buy a similar development board from Xilinx or A.ltera or whoever's FPGA you've selected. You can learn quite a lot by simply examining the assembled board and its documentation. For example, Xilinx usually provides complete schematics, parts lists, Gerber files (PC board artwork), and firmware examples. Xilinx also provides some of those files for free on their web site, so you can preview them without buying anything.
https://www.xilinx.com/products/devboards/index.htm
Here's a helpful little page, Xilinx's "PCB Design Checklist":
https://www.xilinx.com/products/design_resources/signal_integrity/si_pcbcheck.htm
Other companies such as A.ltera probably provide similar resources, although I'm not very familiar with them.
Koson
Junior Member level 2
Bangkok, Thailand.
it's not easy task todo with very high frequency of that FPGA,
if you cant design the PCBs to run faster than few hundred MHz , just buy it.
in digital world , an 100 MHz means you have to design at least 1GHz (up to 9th harmonics) to make "square" logic not "sine"
or you will get bad result from "sine" wave run into your digital cct.
sorry in my english, it's not my first language. :)
