FPGA driven by external clock
ttse7
Junior Member level 2
I have got a altera stratix II dsp board and built a nios softcore cpu inside. I try to drive the fpga using a clock from a external hardware. My problem is the clock form external hardware cannot drive the PLL inside the fpga.
When I monitor the clock to be input to fpga, the duty cycle is varied but meaured frequency is still 66MHz. Now, nios sometimes fails to work due to the external clock.
Experts, can you help?
I can use the clock to drive the nios by using fpga built-in clock without any problem. My project needs fpga to work with this external hardware. How to incorporate two hardware with two different clocks?
Iouri
Advanced Member level 2
Cut the trace from external osc and put desired osc, or you you can use PLL component from SOPC builder, and use "original" osc
mmarco76
Member level 5
Have you put the external clock in a input of the the PLL?
Depending on the exactly device some pins are specified to be the one that enter in the PLL.
Have a look on the Stratix2 pdf and then cut the trace of the clock and wire it to the right pin.
