May 13, 2008 #1 L lakshman.ar Member level 5 Joined Nov 29, 2006 Messages 87 Helped 12 Reputation 24 Reaction score 4 Trophy points 1,288 Location Bangalore Activity points 1,849 what is a four corner analysis ? i hope every1 is familiar with 2 corner analysis ( setup analysis performed with WC lib & hold analysis performed BC lib) ... Now is it required to do the setup analysis with BC lib and hold analysis with WC lib as well ? ..... Is this called four corner analysis ? cheers Lakshman
May 13, 2008 #2 L ljxpjpjljx Advanced Member level 3 Joined May 5, 2008 Messages 968 Helped 80 Reputation 162 Reaction score 56 Trophy points 1,308 Location Shang Hai Activity points 4,679 yes,also you should include the SI analysis!
May 13, 2008 #3 L lakshman.ar Member level 5 Joined Nov 29, 2006 Messages 87 Helped 12 Reputation 24 Reaction score 4 Trophy points 1,288 Location Bangalore Activity points 1,849 But how does Performing a Setup analysis with BC lib and hold analysis with WC lib help ? What are the advantages of performing a Four corner analysis ? Ne kinda documents related to the same if uploaded will be relli useful ! To all the Masters of STA ... has anybody performed the same kinda analysis ? If so kindly thro some light into this ! Any kinda help will be really useful . Thanks in Advance !
