mitul121
Newbie level 5
Battery back up
I currently have a set up where I have attached a permanant magnet dc motor to a bicycle. The motor is attached through a diode to a 12v regulator and then to a 12v to 240v inverter. Everything works fine and I can power up my devices.
But I have been told that if I connect my 12V lead acid gel battery to the inverter as well via a diode, this will act as a back up source, so if I stop pedalling, the battery will power the inverter via a process called forward/reverse biasing.
Please can I get some advice on this and whether it will work? I know this may seem a bit basic but I am in the learning process still, so any help will be appreciated.
Thanks
Mit
Thanks
Mit
