Formula for calculating DAC output
graciousparul
Full Member level 2
The logic levels used in a 6-bit R-2R ladder DAC are 0=0v and 1=+5v.What is the binary input when the analog output is 4V?
Thanks in advance...
Re: DAC
(4÷5)64 in binary.
Regards,
Laktronics
Re: DAC
i think major are saying right
Re: DAC
hi laktronics,
Can u say me is this standard formulae of just...?
Re: DAC
Hi friends,
The standard formula for calculating the DAC output is, for example of 6 bit DAC
Output of DAC in Volts =
((32*D5 + 16*D4 + 8* D3 + 4*D2 + 2*D1 + 1*D0)*SUPPLY VOLTAGE)/(2 POWER 6)
Thats all.
All the best,
N.Muralidhara
Re: DAC
graciousparul said:
hi laktronics,
see the attached jpg.
hello laktronics you also check it and please let me kno is it true or false..??
Thanks you..
Re: DAC
Hi H_D_R,
The equation given by you is same as that given by Mr Murali as shown below:
Vo = KRf ( A1/2 +......+ A8/256) ----(a) ; where A1..A8 is a binary number
From the above equation,
Vref = KRf (1) ----(b) ; (A1/2+... +A8/256) =1 since for Vref A1 to A8 all are one.
Dividing (a) by (b),
Vo/Vref = (A1/2 +.....+A8/256)
Multiplying both sides by 256,
(Vo/Vref) 256 = (128.A1+64.A2 +......+ A8 ) ....(c) which is same as Mr.Murali's
eqtn. applied to a 6bit DAC.
The above eqation (c) will be valid for unipolar DACs.For bipolar offset binay DACs also it will hold good if you take Vref as total span of -Vref to +Vref.
The equation also applies to similar ADCs if you replace Vo by Vin.
Then there are sign magnitude and 2's complement codes for which +ve and -ve outputs are coded separately.
Regards,
Laktronics
Re: DAC
yes, i knew that laterly...
bt i think this will make more clear to my friend "graciousparul".
thats it...
