xpress_embedo
- Joined
- Jul 5, 2011
- Messages
- 1,154
- Helped
- 161
- Reputation
- 396
- Reaction score
- 189
- Trophy points
- 1,353
- Location
- India
- Activity points
- 10,591
Hello!! Everyone,
I have to convert Ip address array written in Decimal form to String form, i have written this code for it.
// First Function
This functions works properly, but i need some small code for that, which is as follow:
// Second Function
Both functions works properly, just with a difference as below:
First Creates array as "192.168.001.017"
while second creates array "192.168.1.17"
Is it possible with snprintf to create an array of string similar to the one obtained by first function.
Hello!! Problem Solved.
By Using This Line.
Code C - [expand] 1 2 char IP[4] = {192,168,1,17}; char IP_Address[16];
// First Function
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 void ConvertIpToString(char *IP,char *IP_Address) { *(IP_Address) = ((*IP)/100)|0x30; *(IP_Address+1) = (((*IP)/10)%10)|0x30; *(IP_Address+2) = ((*IP)%10)|0x30; *(IP_Address+3) = '.'; *(IP_Address+4) = ((*(IP+1))/100)|0x30; *(IP_Address+5) = (((*(IP+1))/10)%10)|0x30; *(IP_Address+6) = ((*(IP+1))%10)|0x30; *(IP_Address+7) = '.'; *(IP_Address+8) = ((*(IP+2))/100)|0x30; *(IP_Address+9) = (((*(IP+2))/10)%10)|0x30; *(IP_Address+10) = ((*(IP+2))%10)|0x30; *(IP_Address+11) = '.'; *(IP_Address+12) = ((*(IP+3))/100)|0x30; *(IP_Address+13) = (((*(IP+3))/10)%10)|0x30; *(IP_Address+14) = ((*(IP+3))%10)|0x30; *(IP_Address+15) = 0; // Null Character }
// Second Function
Code C - [expand] 1 2 3 4 void ConvertIpToString(char *IP,char *IP_Address) { snprintf(IP_Address,16,"%d.%d.%d.%d",*IP,*(IP+1),*(IP+2),*(IP+3)); }
By Using This Line.
snprintf(IP_Address,16,"%.3d.%.3d.%.3d.%.3d",*IP,*(IP+1),*(IP+2),*(IP+3));
