Formal Logic Equivalent Check (LEC)
davyzhu
Advanced Member level 1
oriental
logical equivalence check
Hi all,
When do Formal Equivalent Check (RTL and Gate Level) , I remember that the tool compare the comb logic between D-FF .
But when synthesis use re-timing and gated clock, can LEC tool compare
RTL and Gate?
And is gated clock one form of re-timing?
I am reading a paper from SNUG about gated clock (How to successfully
use gated clock...) but I cannot understand the waveform...
Best regards,
Davy
logic equivalence check
davyzhu said:
Hi all,
Best regards,
Davy
Gated clock is not a form of re-timing, it is used for saving power.
Can you show your waveform, and explain detailedly.
    davyzhu
synopsys lec
in lec
set flatten model -gated_clock
will solve the problem
    davyzhu
formal equivalency check
synopsys dc
formality
    davyzhu
logic equivalent
hi all,
if u r using the synopsys DC and formality.the DC will give the SVF file as output while doing the synthesis.which will give the gudence to the formality.so that the logical equvalency for the rtl vs netlist will pass.
regards,
rameshs
    davyzhu
logic equivilant to exclusive -or gate
HOw about design with ICG cells ?? like ICG cells from artisan ... ??
