For which application is floating point calculation required
pixel
Advanced Member level 2
floating point
Lot of computing can be done with fixed point, which is much faster than floating point calculation on microcontrollers.
For which application is the floating point necessary in microcontrollers systems?
rkodaira
Full Member level 6
Sao Paulo - Brasil
Re: floating point
Hi !
Floating point operation should be avoided if possible. It spends a lot of commands, memory and processing. But sometimes, you have to deal with fractionary very smaller or numbers very larger than fixed point numbers of 2 (65,536) or 4 bytes long (4,294,967,296) or need a good precision.
It is normally used to treat numbers within the range of fixed point (integer) numbers, shifting decimal point right or left (multiplying or dividing by ten). As I made some confusion about it, i´d prefer using standard floating point routines in my PIC programs.
mipedja
Junior Member level 3
Re: floating point
So, as I understood floating point should not be used in fast real time application. Maybe in some slow instrumantation measurement?
stygops
Newbie level 6
Re: floating point
in a program of 89s8252 i used floating point to calculate antilogarithm and after i multiply to show in lcd...
