For Drones: mRo Power Zero with Dual internal Power Supply
pemase
Newbie
This is a renewed high-quality power module standard used to energize drone autopilots that use open software like Ardupilot or Px4 and is based on the ACSP7 but with dual internal power supply to improve the stability of the hall-sensing.
The mRo Power Zero from mRobotics it offers extremely accurate measurements across the entire current & voltage operating range with a non-invasive Hall-effect current sensor for UAV / Robotics application and high precision voltage dividing circuit for consistent and reliable measurements.
Compared to the ACSP7, the .5v offset is removed and the current sensing is compared with a dedicated power reference. The integrated electrolytic capacitor reduces voltage spikes which result from longer input cable lengths and higher voltage batteries.
Download STEP file here (Right click and Save link As)
SPECIFICATIONS:
Power ModulemRo Power Zero
Dimensions18mmx18mm (.70″x.70″)
Height: 7.30 mm (0.28″)
Weight2.5g (0.08 oz)
Maximum input voltage50.4v 12s lipo
Max Current Sensing90 Amps
Max Current from 5.3V Power Supply2 Amps
CompatibilityArdupilot & PX4
