Folding Interpolation ADC SNR problem
chemaphy
Junior Member level 2
Hi Everyone,
I have just designed a 8-bit folding interpolation ADC. When I simulate my ADC, I cannot get to 8-bit of resolution. The SNR that I got from the power spectrum is only -30dB. The noise level is at -40dB. Is there any technique I can use to lower the noise level in the ADC. Can anyone who has experience with folding interpolation ADC let me know which part in the ADC contribute such a high noise?
Thanks,
chemaphy
maxwellequ
Full Member level 3
A few questions:
Are you making a transient simulation with noise ?
How many fft points have you used ?
Do you get distortion ? To what level ?
Regards
chemaphy
Thanks to your reply maxwellequ. The transient simulation that I have used is a typical one. It should not have any noise component in it. The simulator that I used was hspiceD. The noise floor in the simulation result was -40dB, and the distortion level is -30dB. Is there anything I can do to lower the distortion and noise level? Thank you very much for your time maxwellequ!
maxwellequ
Full Member level 3
HSPICED ! Don't you mean HSPICE ?
Can you attach the FFT result figure ?
Anyway, the only reason to have distortion is a design error in one of the blocks. For example:
- Do you use S/H ? If yes, have you simulated it standalone (with its load, of course) ? Do you see any relevant distortion there ?
- Are you sure that the folding stages are settling fast enough ?
- Are there any DC deviations in the zero crossings of the folding stages ?
- Are your comparators fast enough ?
In what concerns the high noise floor, how many points have you used in the FFT ? If the number of points is low, then this may explain the high noise floor.
Regards
neoflash
Advanced Member level 1
if u are familiar with cascaded folding, maybe you can help me explain it.
Added after 37 seconds:
By the way, you can not get noise from transient simulation in hspice. Never.
