davyzhu
Advanced Member level 1
learning to find folded cascode w to l ratio
Hello all,
I am learning Analog COMS IC (for two month) and using Allen's book, there he talked about the folded-cascode opamp.
I calculated one of his Ex, and simulated the result, but found the two current mirror transistrors and two output transistors are working in the cutoff region, but I do not know how to make the transistors working in the saturatied region.
Allen said in his book that analog designer should have a intuitive approach in design. But I always found it is hard for me to gain that intuition. Can you give me some suggestions and references?
Regards,
Davy Zhu
Hello all,
Regards,
Davy Zhu
