Hello
I would like to detect a voltage threshold with isolation. I have found this chip: fod2741. However, I see many examples for AC applications (switching), but the voltage I want to measure (which is high voltage that I will divide through resistors divider) is a DC voltage.
I could not find any application note, will it work? I do not need to measure the voltage, just to set a threshold. In practice I want something that behaves as a comparator that outputs a trigger when the voltage goes over a certain value, but with insulation.
Thanks
