Assuming 4 digits readout is sufficient, every tenth of a second...
You must first scale down the carrier frequency, by using a series of divide-by-10 stages.
Then run the result to a frequency counter. Then to the LCD. There are all-in-one IC's to make this part easy.
It's likely you can do all the above with a microcontroller. (I have no experience with them.)
If it cannot handle 100 MHz waveforms then you'll still need to use one or more separate pre-scalers.
