FLYWHEEL generator design.
vinay.reddy
Newbie level 1
Newbie level 1
Hi all,
I designed flywheel generator with 3kW power, 110v . while doing 2d analysis am not able to match up Eddy current density. Can anyone help me with appropriate formula to calculate eddy current density in generator/motor.
Use Faraday’s law to get the function of the radius than use Ampere's law to model the magnetic field as a function of radius.
The magnetic fields... in your case are used to calculate the potential heat and drag.
