ku637
- Joined
- Apr 6, 2011
- Messages
- 116
- Helped
- 2
- Reputation
- 4
- Reaction score
- 3
- Trophy points
- 1,298
- Activity points
- 2,551
Hello experts,
I just wanted to design my first flyback converter.. so after some initial search i obtained a pre built flyback converter transformer whose characteristics are
So after some study i thought it will be better to do a a design around UC3845 and experiment..
So i built a PCB and used a generic schematics,
And when i observed at 85 VAC input, i got pretty 12V which can load up to 1.5A.. i don't know how can i improve it up to 3A capability..
But then i tried another possibility
I just changed the output resistor divider to obtain VOUT=5V
but now the load capacity is dramatically poor it can't give even 500mA..
I tried to observe the waveform using a 100x probe at the VDS, it appears that the converter is running in DCM,
I tried to increase the fsw to 150 kHz, as in DCM i thought P=[1/2*L*(Ip)²]*fsw no improvement in load capacity
I tried to decrease sense resistor value to 1 Ohm i.e Ip is set to 1A (i.e 1V/1 Ohm) still it cant load up to 500mA and the converter appears pretty instable.
So my question is,
From Pressman
f=100kHz, Lprim=290uH, Np/Ns=14 , Np/Naux=10 This transformer was designed to be used with a 12/3A SMPS operating from 85-265VAC
VIN =85-265VAC
VOUT=12V
Iout desired =3A
Feed back TL431+OPTO
OSC FREQ=100kHz
SENSE Resistor i put 2.2Ohm i.e it will give 1/2.2Ohm =454 mA primary peak current.
Auxillary winding is generating 16V to power IC as expected.
MOSFET and other components sized as per requirements to best of my knowledge.
So my question is,
- Whether it is possible to use a transformer designed for 12V output to work for 5V output?
- Will the turns ratio have much impact to prevent it?
From Pressman
The rules for an inductor with more than one winding are as follows:The primary to secondary ampere-turns ratios are conserved (not the voltage ratios, as was the case with a true transformer). For example,if the primary is, say, 100 turns and the current when Q1 turns “off” is 1 amp, then we have developed 100 ampere-turns in the primary. This must be conserved in the secondaries. With, say, a single secondary winding of 10 turns, the secondary current will be 10 amps (10T×10A = 100 ampere-turns). In the same way, a single turn will develop 100 amps or 1000 secondary turns will develop 0.1 amps.So where do we stand with regard to voltage? Well, to the first order,there is no correlation between primary and secondary voltages. The secondary voltage is simply a function of load. Consider the 10-turn 10-amp (100 ampere-turns) secondary winding example mentioned above. If we terminate the winding with a 1-ohm load, we will get 10 volts. What is more striking because the 10 amps must be con-served is that if we terminate it with 100 ohms, we will get 1000 volts!
This is why the flyback topology is so useful for generating high volt-ages (don’t try to open circuit this winding because it will destroy the semiconductors). With several secondary windings conducting at the same time, then the sum of all the secondary ampere-turns must be conserved.
