sprasannaatsjec
Newbie level 1
- Joined
- Oct 28, 2014
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 13
Hello guys,
I am simulating a flyback converter in PSPICE,
I am getting excellent results when i simulate with "VPULSE" signal to MOSFET, But when i put the actual model of the PWM controller with max duty cycle 50% , i observe that the the converter starts with 50% duty cycle for few cycles, now the out put increase above the desired value and the the controller shutdown without any pwm signal, after few usec the output volatge reduces below the required and pwm controller generates burst of pulses , and voltage rises and controller turns off. and the cycle repeat.
The interesting thing is tat the actual circuit works perfectly with different load condition, which working fine in real hardware.
any suggestion to check???
regards
Prasanna sinthaje
regards
Prasanna sinthaje
