Floating point - showing the temp in lcd
gafar
Junior Member level 1
Brazil
Floating point
I need show the temp in the Display lcd.
Range temperature = 0 ~ 128 °C
Range AD = 00h ~ FFh
1 step 0,5°C = 128/256
35°C = 46h * 0.5
How i do it use assembly to 8051???
Can you help me
Thanks
i havent worked wth 8051
but an idea is to make H46 * 5 get the answer and display the decimal point urself on the second digit . Of course u have to do a hex to decimal routine before displaying .
regards
:idea: Thanks for open my mind.
Re: Floating point
its quite simple actually using the mul and div instructions
Re: Floating point
u can use normalization to implement FPU .. no need to actually implement FPU
represent the non-decimal part by say 7 bits ... and then assign another say 3-4 bits for the decimal portion....
Re: Floating point
hi
u can use Look Up Table or Hex to Decimal algorithm to convert data
:idea:
Re: Floating point
At http: //xavier.fenard.free.fr/LCMeter.htm
you have an exemple of float routine for a small
avr. Change only the appl. prog....
lucas
