FLOATING Point Math for PICMicro
isabelino
Member level 1
Please: I need routines about cosine and sine , on Picbasic or PICC compiler. I need precision , more than 32bit floating point, because I need to calculate seconds. I working on Pic18F452 micro
Thanks .
Regnum
Full Member level 5
Hurlingham
All the functions I've seen are 32-bit... maybe you should code it by yourself
Make a search for CORDIC algorithms
Regards.
isabelino
Member level 1
Please: I need routines about cosine and sine , on Picbasic or PICC compiler. I need precision , more than 32bit floating point, because I need to calculate seconds. I working on Pic18F452 micro . Cordic is good, but not is a solution because I need to calculate seconds.
Thanks,please
SphinX
Advanced Member level 3
EGYPT
Salam,
You can use these codes with PICC with some modification.
////////////////////////////// Trig Functions //////////////////////////////
#undef PI_DIV_BY_TWO
#define PI_DIV_BY_TWO	1.570796326794896
#undef TWOBYPI
#define TWOBYPI 			0.6366197724
//	float cos(float x)
// Description : returns the cosine value of the angle x, which is in radian
// Date : 9/20/2001
float cos(float x)
	float y, t, t2 = 1.0;
	int quad, i;
	float frac;
	float p[4] = {
		-0.499999993585,
		 0.041666636258,
		-0.0013888361399,
		 0.00002476016134
	if (x < 0) x = -x;                  // absolute value of input
	quad = (int)(x / PI_DIV_BY_TWO);    // quadrant
	frac = (x / PI_DIV_BY_TWO) - quad;  // fractional part of input
	quad = quad % 4;                    // quadrant (0 to 3)
	if (quad == 0 || quad == 2)
		t = frac * PI_DIV_BY_TWO;
	else if (quad == 1)
		t = (1-frac) * PI_DIV_BY_TWO;
	else // should be 3
		t = (frac-1) * PI_DIV_BY_TWO;
	y = 0.999999999781;
	t = t * t;
	for (i = 0; i <= 3; i++)
		t2 = t2 * t;
		y = y + p[i] * t2;
	if (quad == 2 || quad == 1)
		y = -y;  // correct sign
	return (y);
and
//	float sin(float x)
// Description : returns the sine value of the angle x, which is in radian
// Date : 9/20/2001
float sin(float x)
	return cos(x - PI_DIV_BY_TWO);
Bye
