floating point calculations on AT89s8252
dnarenderreddy
Junior Member level 2
hi all, i want to calculate the result of the expression
ah = (range * count*10*resolution)/(3600*1000);
and later add it to the previous value of it
ahfinal = ahfinal + ah;
in brief to explain what i want actually is: count is the count of pulses on timer/counter , now these pulses are caliberated as
range ------> 1000 pulses
xxxx -------> count pulses
now these are to be cailberated into one hour
so ah = xxxx/3600;
now i need a resolution of (1 or 2 or 3 decimals depending on the variable resolution. next the final result should be integrated( i mean added to its previous value ahfinal = ahfinal+ah)
here
range (25, 75,100)
resolution(1, 2, 3)
count(some bog number assume around 1000).
i dont know how to deal with floating point values in microcontroller programming. can anyone help me
thanks in advance
narender
