shaiko
Advanced Member level 5
- Joined
- Aug 20, 2011
- Messages
- 2,644
- Helped
- 303
- Reputation
- 608
- Reaction score
- 297
- Trophy points
- 1,363
- Activity points
- 18,302
I wrote this code for generic multiport memory.
When the "NUMBER_OF_WRITE_PORTS" , "NUMBER_OF_READ_PORTS" generics are instantiated to a value higher then 1, a multiport flip-flop based memory is successfully generated.
However, when the "NUMBER_OF_WRITE_PORTS" , "NUMBER_OF_READ_PORTS" generics are instantiated to 1 - I expect the synthesis tool to see that the complex multi port memory degenerates to simple block RAM.
But this doesn't happen. The RTL viewer shows that flip-flops (and not RAM) remain the bulding block of the memory matrix.
Why does this happen?
entity memory is
generic
CELL_WIDTH : positive := 8 ;
NUMBER_OF_CELLS : positive := 4 ;
NUMBER_OF_WRITE_PORTS : positive := 1 ;
NUMBER_OF_READ_PORTS : positive := 1
port
CLOCK : in std_logic ;
WRITE_REQUEST_VECTOR : in std_logic_vector ( NUMBER_OF_WRITE_PORTS - 1 downto 0 ) ;
READ_REQUEST_VECTOR : in std_logic_vector ( NUMBER_OF_READ_PORTS - 1 downto 0 ) ;
WRITE_ADDRESS_ARRAY : in type_array_unsigned ( 0 to NUMBER_OF_WRITE_PORTS - 1 ) ( log_2_decimal ( NUMBER_OF_CELLS ) - 1 downto 0 ) ;
READ_ADDRESS_ARRAY : in type_array_unsigned ( 0 to NUMBER_OF_READ_PORTS - 1 ) ( log_2_decimal ( NUMBER_OF_CELLS ) - 1 downto 0 ) ;
INPUT_DATA_ARRAY : in type_array_slv ( 0 to NUMBER_OF_WRITE_PORTS - 1 ) ( CELL_WIDTH - 1 downto 0 ) ;
OUTPUT_DATA_ARRAY : out type_array_slv ( 0 to NUMBER_OF_READ_PORTS - 1 ) ( CELL_WIDTH - 1 downto 0 )
end entity memory ;
architecture synthesizable_memory of memory is
type type_array_data_memory is array ( 0 to NUMBER_OF_CELLS - 1 ) of std_logic_vector ( CELL_WIDTH - 1 downto 0 ) ;
signal memory_matrix : type_array_data_memory ;
begin
writing : process ( CLOCK ) is
begin
if rising_edge ( CLOCK ) then
for index in INPUT_DATA_ARRAY ' range
loop
if WRITE_REQUEST_VECTOR ( index ) = '1' and PORT_IN_SLV_ENABLE ( index ) = '1' then
memory_matrix ( to_integer ( WRITE_ADDRESS_ARRAY ( index ) ) ) <= INPUT_DATA_ARRAY ( index ) ;
end if ;
end loop ;
end if;
end process writing ;
reading : process ( CLOCK ) is
begin
for index in OUTPUT_DATA_ARRAY ' range
loop
if READ_REQUEST_VECTOR ( index ) = '1' then
OUTPUT_DATA_ARRAY ( index ) <= memory_matrix ( to_integer ( ( READ_ADDRESS_ARRAY ( index ) ) ) ) ;
end if ;
end loop ;
end if;
end process reading ;
end architecture synthesizable_memory ;
