flex sensor with LCD using pic16F877a
MichelleVC
Newbie level 3
hi
i am trying to make a an electronic glove using flex sensor to display the sign language on the LCD . The sensor at rest gives a 10k resistance and when bent upto 25k . with my finger movement ill get a varying resistance for every alphabet . i have connected the sensors to a voltage divider each , i.e, 5 sensors each to 5 voltage dividers , where i get voltage from 3.9V to 2.5V, slight variations for the diff sensors . then the voltage output i connected to a voltage follower to get lower impedance . now i have to give it to the PIC16F877a that i am using . Is it feasible to use PIC16F877a or shud i opt for PIC18F452 . i am new to programmin in C and would like help in how to proceed with the program . i understand assembly language better but for my project i ve to do in C .. i would really appreciate the help ..
Thanku :)
The flex sensors as told by many websites are not availble in the stock. please check the availability of it. I faced lot of problem in getting it and later had to break old LCD and use the flexible materials to make my own ciruit. Still i find it hard to get those sensors. Any controller is fine for that.
---------- Post added at 11:27 ---------- Previous post was at 11:25 ----------
Once you can confirm its availability then it is better to think of suitable language and controller.
At least in india i did not get this sensor. maybe you can try your luck
i have bought 2 flex sensors . u can check da website rhydolabz.com ... 1 flex sensor is 850 bucks another 100 for shipping ... its based in cochin .... i had no problems with buyin the flex sensor ... i tried making but had problems with the material ... i have already used the flex sensor , connected it to a voltage divider and then volt follwer like i already posted b4 ...my main problem now is programmin the PIC for ADC and also the PIC to LCD ... need help in that
Yes but i wud like to program with PIC for the ease of it ... programmin is easier .... i wud jus like to know sample programs after i convert my 5 analog inputs to digital outputs ... how exactly do i program the digital outputs of the various inputs which is in hexadecimal to give an alphabet .... i jus wanted a sample program or some other program of the similar application ...
hi sir i am prathap.
i am doing project on sign language to text translator and text to animation sign language.
i need layout of this project.
what are the requirements for this project?
what are the modules?
where to start how to start?
