Flash memory is a non-volatile memory device that retains its data when the power is removed. The device is similar to EPROM with the exception that it can be electrically erased, whereas an EPROM must be exposed to ultra-violet light to erase.Flash memory does not need a constant power supply to retain its data and it offers extremely fast access times, low power consumption, and relative immunity to severe shock or vibration. These qualities combined with its compact size, make it perfect for portable devices like scanners digital cameras, cell phones, pagers, handhelds and printers. Flash chips.
A RAM-ROM hybrid that can be erased and rewritten under software control. Flash is an in-circuit programmable nonvolatile memory segmented into blocks called sectors. Each sector can be individually erased, then the data within it rewritten.
