carrot
Full Member level 3
- Joined
- Feb 23, 2004
- Messages
- 182
- Helped
- 9
- Reputation
- 18
- Reaction score
- 4
- Trophy points
- 1,298
- Location
- Bangalore, India
- Activity points
- 1,532
satyakumar said:Hold time fixing:
2) adjusting clock speed
Generally hold time is not in the user control
carrot said:Hi,
How to fix Timing Violations(Setup & Hold time Violations)?
What are all the things that has to be taken care while fixing it?
atuo said:Holdup violation can be fix by insert buffer.
Thanks.
In one of my projects
I have got timing violations for a same register at different times. I wanted to know if though the timing violations are at different times, fixing one would fix the other violation at different time also right?
Hi , can anyone explain Negative Values in Setup and Hold Checks?
hi carrot
hold and set up violations are mutually exclusive and vilations can be adjusted with the combi delays and these delays will be more if u increase working temp and will be less if u decrese temp ..just this is my thoguht please suggest me whether its possible in real time or not and tell me if there is any problem with playing temp
Hi Carrot,
After manufacturing of chip, if you are getting hold violation. then it will not work. But still if you want to make it work, go to lab, increase the lab temp depending on your hold time violation, since hold violation is inversely proportional you can make it work.
