When you talk about the mesh higher then 1 million, you're mean the mesh line ration limit? And about the equil~ ratio I don't know what you're saying, cn you be more specific. And about the llines per wavelenght I put 110, the same to the lower mesh limit, cause if I get a higher number it says that it's out of memory.
Other adjustes that I made is in the maximun number of pulses that I put 100, and in the refine at PEC/lossy metal edges along coordinate axes only that I put 5. So I want to know if this adjustes will help my simulation.
Thanks for the reply.
