fixed point to floating point conversion in Verilog
marufsust
Newbie level 6
Malaysia
HI,
I am Masters Student. for my project purpose i need some floating point calculation. but the input is in 16bit fixed point value. I need to convert this 16bit fixed value to IEEE64 bit Floating format.
7380H = 0111 0011 1000 0000
convert into
0 (100 0000 1101) (1100 1110 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000)
can anyone help me how could i do it in VERILOG?
thanx in advance
MAruf
FvM
Super Moderator
Staff member
Bochum, Germany
The operation involves:
- conversion of 2's complement to sign-magnitude representation (for negative numbers)
- normalization (shift left until MSB = 1, adjust the exponent respectively)
marufsust
Newbie level 6
Malaysia
I tried my code is like this
module normalize_integer(clock,operand,result);
input clock;
input [15:0] operand;
output [63:0] result;
reg [4:0] i = 5'b01111;
reg [15:0] store;
reg [51:0] mantissa;
reg [10:0] exponent;
reg [63:0] result;
always@(posedge clock)
begin
store <= i?(operand==1'b1)?i:i<=i-1'b1:0;
exponent <= 11'b01111111111 + store;
mantissa <= operand <<< (52-store) | 52'b0;
result <= {1'b0,exponent,mantissa};
end
endmodule
but its not working :(
FvM
Super Moderator
Staff member
Bochum, Germany
The code would be a good candidate for a newspaper's quiz page. :)
There's no harm in placing only one assignment per code line and using the redundant space for a comment.
At least the exponent calculation seems wrong. The code only handles unsigned numbers. But generally, I would expect something like this.
The combination of a clocked iteration for store and an n-fold shift of the mantissa is most likely not optimal for hardware implementation. You would either try to calculate the result in one cycle, or shift the mantissa incrementally.
marufsust
Newbie level 6
Malaysia
Ya you are right. Its wrong code. But i am new to verilog. do you please clarify a bit more? Or ny suggestion how to fix this issue?
