Fixed point multiplication in Verilog
krishvamsi
Junior Member level 2
i have two 8 bit signed numbers which i'd represented in fixed-point . one is -3.15 = 1100.1110 , other number is 5.1 = 0101.0010 . now i want to obtain the product of these two numbers in verilog. Manually i got the product as 0100000111111100 which is not equal to -16.065. how should i make it equal to manual result ?
FvM
Super Moderator
Staff member
Bochum, Germany
What's the intended result format? You are apparently using signed 4.4 format, the "manual multiply" result isn't correct for signed multiply.
krishvamsi
the intended result should be in 16 bit signed fixed-point format which should be equivalent to that actual product i.e -16.065
asdf44
Advanced Member level 3
I see -50*82=-4100
Shift 8 for the 4+4 fractional bits:
-4100/2^8 = 16.0156
Looks correct with a little rounding error
krishvamsi
16 bit what? 8.8?
I get 11101111 11111100 in signed multiply.
yes exactly . can u tell me the logic u used ? i'll be using it in verilog
I see -50*82=-4100
-4100/2^8 = 16.0156
can u please elaborate this ? i have 5.1 and -3.15 . from where u got -50 and 82 ?
asdf44
From the binary values in your own post
11001110 is -50
01010010 is 82
That's what the values are to the verilog code (if declared as signed).
wire signed [7:0] a = 8'b11001110;
wire signed [7:0] b = 8'b01010010;
wire signed [15:0] c = a*b;
C is 11101111 11111100 or -4100 in signed decimal
