Fix point Arithmetic
sheikh
Hello Dear
I want to use some arithmetic operations such as (+,_,*) in my design. The design is fix point. Could you please tell me, If I use (+,_,*) symbols in my vhdl code, is it synthesize correctly or not? Or I need to design the units ( n_bit full adder, for instance) then write the code structurally. ( consider it that, I don't start to coding, because I'm not sure about the true way)
Regards
Mostafa
shaiko
Advanced Member level 5
+ - * are synthesizable - the performance between one device to another will vary because of the actual implementation of the synthesis tool , different architecture and available "hardened" logic components on the silicon die...
Division however, is synthesizable for constants and 2^n numbers only...you'll have to built your own logic if you want to do division
Reactions: sheikh
    sheikh
sheikh
Thanks Dear shaiko
Could you please tell me which one is better for a design?
1_ using structural coding. 2_ using symbols ( I mean, using "+", instead of an adder unit)
Thanks in advance
Mostafa
shaiko
Unless you're required to use specific logic components that may be inaccessible with the regular arithmetical operators - I see no point to use structural coding.
Even more, VHDL gives you a great tool (functions) to implement any pure combinatorial logic without resulting to structural coding.
sheikh
Thanks a lot
TrickyDicky
no need to write your own divider. both altera and xilinx provide divider ip cores.
also have a look at the new fixed point vhdl packages. for 93 compatible versions see WWW.vhdl.org/fphdl
shaiko
TrickyDicky,
using IP's means that the user will have to result to structural coding...
