kidi3
Full Member level 1
I trying to build a sound bar, which uses the output of an mic, to indicate the sound level in a room.
This is my first Electronic project, so I hope you would bear that mind, before you respond.
My diagram look like this
https://snag.gy/wxmIt.jpg
My idea is to use Comparators, and use it to compare it with a ref. voltage set by me, and thereby visualy show the sound level, with the diodes.
I haven't put any values for my resistor, since I haven't choosen the mic i am going to use.
As for Voltage source I was thinking of using Batteries, which using as many diodes as i am doing will end up being alot. I calculated that i min. should use around 50 V, if i Used resistors with 1 ohm. but could this be done more effeciently???
Ground is another thing that bothers me.. I don't know i should implement it in my PCB?
I haven't choosen a Mic yet, anyone you would recommend?
And using the diagram i've drawen, would it even be possible build a circuit that iam looking for,have I made any mistake, or could something have been done more effeciently?
Thanks in advance
// Kidi3
Thanks in advance
// Kidi3
