nadia32
Newbie level 1
hi
i am new with programming and i want to run this finger print
for adding a new person to system i should use this cod:
which the last byte is the check sum
in data sheet says that :
Check sum:
Low 8 bytes of the SUM from packet head to check sum.
but what should i do when my id is more than 7? because check sum will more than one byte??!!!!
0x4D + 0x58 + 0x10 + 0x03 + 0x40 + [U]0x00 + 0x00[/U] +[B] 0xF8[/B]
Check sum:
