Finger Print scanner interface
Deepesh Khaneja
Newbie level 6
I have purchased an R305 finger print scanner module and tried to interface with atmega16 serially but i didnt get any response from fingerprint scanner module .I have written a C code for testing my scanner which i will use in my future project.
Anybody has an experience of working with this kind of scanner pls reply then i will post my c code and tell me whats wrong.Finger print Scanner
Deepesh Khaneja
Newbie level 6
#include<avr/io.h>
#include<util/delay.h>
#include<stdio.h>
#define Baud_rate 57600
#define Xtal 16000000
#define Ubbr_value (Xtal/(16*Baud_rate))-1
void uart_init()
UCSRB|=(1<<TXEN)|(1<<RXEN);
UCSRC=0X00;
UCSRC|=(1<<URSEL)|(1<<UCSZ1)|(1<<UCSZ0);
UBRRL=Ubbr_value;
UBRRH=0X00;
void send_byte(char *str,unsigned int l)
unsigned int i=0;
while(l--)
while(!(UCSRA&(1<<UDRE))) led_blink();
UDR=*str;
str++;
if(l==1)
PORTA|=(1<<2);
void led_blink()
PORTA=0X01;
_delay_ms(100);
PORTA^=(1<<0);
_delay_ms(100);
int main()
unsigned char GenImg[]={0xEF,0x00,0xFF,0xFF,0xFF,0xFF,0x01,0x00,0x03,0x01,0x00,0x05};
int len=13;
DDRA=0XFF;
PORTA=0X00;
uart_init();
_delay_ms(500);
send_byte(&GenImg,len);
_delay_ms(500);
return 0;
hey jayanth have you got any solution to this code as it it compiles without error but after flashing the scanner doesnt respond..
Help me please
Deepesh Khaneja
Newbie level 6
AVR atmega16 .....trying to communicate with scanner serially by sending GenImg array commands for generating and storing image
Bangalore, India
I don't use AVR. I use PIC. If you want help then mention which bit of which register is to be set or cleared to enable UART receive interrupt. I will write a code in mikroC PRO AVR for testing.
