I’m very lost with this problem. I thought I knew this stuff. This is a exercise problem.
What is the value XL in the circuit. The absolute value of Es is 100V. It says, first find Z, noting E and I are given. Next Find X, then XL.
Where does X come in? I’m just drawing a blank on this one.View attachment CIE 5231-2.pdf
XL conventionally is inductive reactance.
Basic formula:
XL = 2 * Pi * f * L
This does not necessarily pass the same current as a pure ohmic resistance. To be accurate you need to make the adjustment by drawing the parallelogram angles, which has to do with phase.
1) Z = E/I = (100<alpha)/(2<0) = 50<alpha
2) X = sqrt (Z^2 - R^2) --- complete this one yourself. I believe alpha is 90deg so take note.
3) X = XL-XC... XL = X+XC (complete this one too)
Yes, thank you but I knew that one. However they do not mention any frequency in this problem.
But I appreciate your response. I believe the next response from Akanimo is what I was missing. But really, thank you so much for replying.
Yes albbg, you are right. I made mistakes with the computation. There is even another one in line 3 of post #7. It should have been X = sqrt (2500-900)... but I wrote X^2 = sqrt (2500-900)... by mistake.
