Register Log in
Finding certain string in file using bash shell scriot
Abdo_Mgdy
Newbie level 6
I need to develop bash shell script extracting capacitance values of nets from post pnr spf file and put them in a column vector.
The spf file is like following:
Code - [expand]
8
9
10
11
*|NET top33_dft_1/top33_orig_1/rf0_1/n503 0.008406PF
*|I (top33_dft_1/top33_orig_1/rf0_1/U924:A1
*+ top33_dft_1/top33_orig_1/rf0_1/U924 A1 I 0.002625PF 184.520 304.920)
*|I (top33_dft_1/top33_orig_1/rf0_1/U918:A2
*+ top33_dft_1/top33_orig_1/rf0_1/U918 A2 I 0.002814PF 189.000 289.240)
*|NET top33_dft_1/top33_orig_1/wradd_hold/FE_OFN38_smc18_rf_wradd_hold_1_
*+ 0.000132PF
*|I (top33_dft_1/top33_orig_1/wradd_hold/FE_OFC37_smc18_rf_wradd_hold_1_:ZN
*+ top33_dft_1/top33_orig_1/wradd_hold/FE_OFC37_smc18_rf_wradd_hold_1_ ZN
I need to capture only the value after net name, i.e. first value after "*|NET". How can I do it??
std_match
Sweden
This is a job for "sed" or "awk", but I think you should tell us the expected output from your example.
Is the "*|NET" always on the same line as the value?
ads-ee
Super Moderator
Staff member
USA
It also looks like the value may be on the next line which the line continuation is denoted by "*+". See lines 7 & 8.
I think I would write a script with Python, Perl, Ruby, whatever than use command like sed/awk to do this. You can still call the script from a bash shell.
ThisIsNotSam
Advanced Member level 5
Code - [expand]
8
9
10
11
*+ 0.000132PF
Literally every programming language or scripting language can be used for parsing this. Use whatever you are more comfortable with. sed/awk look like good candidates here.
Abdo_Mgdy
Newbie level 6
The output shoud be as follows:
Code - [expand]
0.000132
[\syntax]
And, no the value does not always come in the same line
Toggle Sidebar
